crate engine
Old 10-12-2006, 10:05 PM
Dull_Machete
Dull_Machete's Avatar
Default crate engine
i am thinking about buying this engine.
i have a 90' convertible completely stock, what other things will i need to upgrade to make this engine run good? Im thinking of going with a edelbrock rpm 2, what size throttle body? do i need to upgrade fuel system? how much will it cost me to have a mechanic put all of it in?
Dull_Machete is offline
Old 10-12-2006, 11:06 PM
pony7up
pony7up's Avatar
Default RE: crate engine
Why dont you just stroke out the motor you have already ? Coast high performance sells a 347 stroker kit for 750 bucks ! I would stroke it get a better set of heads and intake . I could personally get a better motor for $4,300 (built). I would definatley keep searching ? Jmo.
pony7up is offline
Old 10-13-2006, 12:46 AM
OneFine89Mustang
OneFine89Mustang's Avatar
if your set on that engine summitracing sells that same crate engine for 3479 it is roughly after shipping around 800 dollars cheaper
OneFine89Mustang is offline
Old 10-13-2006, 12:49 AM
88BlueGT
88BlueGT's Avatar
Its a nice motor.... BUT I dont like crate motors............. you can build them for cheaper and get more power. If you dont want to do that they the motor is nice.
88BlueGT is offline
Old 10-13-2006, 01:18 AM
Mthd11
Mthd11's Avatar
crate motors are rediculously expensive, i second on stroking or even forced induction
Mthd11 is offline
Old 10-13-2006, 01:24 AM
88BlueGT
88BlueGT's Avatar
Crate Motors = Less for More
88BlueGT is offline
Old 10-13-2006, 02:27 PM
5.0kidsdad
5.0kidsdad's Avatar
Just put that same motor in my sons 92LX. 288 rwhp and 312 torque. Trick Flow street heat intake, 70mm BBK TB, 76mm C&l mass air, BBK equal length shortys, h-pipe, flowmasters. We are very happy with it so far!
5.0kidsdad is offline
Old 10-13-2006, 02:38 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
was it made in mexico?
2 kwik is offline
Old 10-13-2006, 02:41 PM
GaryBisiniere
GaryBisiniere's Avatar
build it yourself for experience. its badass when you can say ya i built it. do a 306 or 331 with aluminum heads intake cam rockers and throw a carb on it and your set to go!
GaryBisiniere is offline
Old 10-13-2006, 02:44 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
funny thing is most had never even changed a tires and say that
2 kwik is offline
Quick Reply: crate engine
