Harmonic Damper: How to Remove/Install
Old 10-13-2006, 12:54 PM
FutBall23
FutBall23's Avatar
Default Harmonic Damper: How to Remove/Install
Well it took me awhile to fix due to lack of tools needed and the general "know-how" but here is how it was done for anyone else who may come across this problem.
First you start with the parts you will need, pick up a pully puller (harmonic damper puller) along with a socket set. Start with taking off the belt, there is a tensioner that you can fit the un-equipped socket wrench into the square hole to bend the tensioner, you may need a second person to take the belt off while you do this because it will go back into place if pressure is released. After this is done take off the crank pully and then the main bolt in the middle of the harmonic damper, after this use the damper puller to take off the used damper. For installing the new damper there is a couple ways you can go about it but the one I chose was this, take the bolt that was in the middle of the damper and find another bolt same size and thread, just longer, and use it to anchor the new damper on, once you get it far enough to switch bolts back to the actual size bolt do so and finish tightening. Put it all back together and your done. The whole process should take about 2-4 hours if done correctly and all parts are accounted for.
FutBall23 is offline
Old 10-13-2006, 01:50 PM
7upedition
7upedition's Avatar
Default RE: Harmonic Damper: How to Remove/Install
got any pics, if you want to make this a sticky you'll need to be a bit more descriptive and photos ... thanks for the advice though
7upedition is offline
Old 10-13-2006, 03:01 PM
5IVE.OH
5IVE.OH's Avatar
I've done it with a crow bar and gentle hands in under 1 hr. 2nd time I tried I had to buy a new front cover though [:@]
5IVE.OH is offline
LivingInThePast
09-16-2015 12:20 PM
odiaz
08-08-2005 06:46 PM
The02GT
05-08-2005 09:12 PM
hawgman
03-29-2005 02:37 PM
pacepony
09-12-2004 04:15 AM
Quick Reply: Harmonic Damper: How to Remove/Install
