having gas troubles
Old 10-13-2006, 04:22 PM
subhumantat
subhumantat's Avatar
Default having gas troubles
so i have an '87 2.3 auto converted to an '84 5.0 5-speed and after the conversion, my gas gauge i thought was off because I ran out of gas with it reading 1/4 tank. but when i filled up, i could only fit about 10 gals in. now it did the same and the gauge read 1/2 tank. so my question would be is the stock in tank fuel pump unable to keep up with the needs of a very mild built 5.0(idk if the fuel pumps were different between the 2.3 and 5.0) or is it somthing else, need help cause yes it is the begining of winter in wisconsin and i don't have a garage....oh yeh i am running with a stock carb
subhumantat is offline
Old 10-13-2006, 04:39 PM
rrw
rrw's Avatar
Default RE: having gas troubles
Im pretty sure Ive heard about guys running 4cyl pumps in conversions. I will have to ask my buddy at work tonight if his pump in his conversion is stock. He also runs a mildly built engine. GT-40 heads, CAM, Nice upper intake, exhaust,etc.
rrw is offline
Old 10-13-2006, 05:11 PM
Ninety5five0
Ninety5five0's Avatar
Might wanna upgrade it anyways, cant hurt. And it'll be there if you wanna do a power adder later. Just my .02
Ninety5five0 is offline
Old 10-13-2006, 05:41 PM
ryan_89_mustang
ryan_89_mustang's Avatar
It sounds like there could be something wrong with your pick up where it's not reaching the bottem of the tank
ryan_89_mustang is offline
Old 10-13-2006, 05:57 PM
7upedition
7upedition's Avatar
there is a plastic cage in the bottom of the tank which holds the pickup and that may have broke loose and isn't allowing fuel to pickup.
7upedition is offline
Old 10-13-2006, 06:28 PM
subhumantat
ORIGINAL: 7upedition
how would i fix that? new tank, new pump or what?
4cylinderplus2
10-09-2020 07:45 PM
CS2007
06-25-2019 09:45 PM
chrisdbassplayer
10-13-2015 06:53 PM
Sixer4Life
10-12-2015 04:26 AM
b8checker
10-08-2015 12:55 PM
Quick Reply: having gas troubles
