Air Fuel ratio gauge
Old 10-20-2006, 03:35 PM
mustangtt89
mustangtt89's Avatar
Default Air Fuel ratio gauge
What Air Fuel ratio gauge is good to
Whit are cars
And how to install /2 O2 sensors
mustangtt89 is offline
Old 10-20-2006, 04:26 PM
OnyxCobra
OnyxCobra's Avatar
Default RE: Air Fuel ratio gauge
what the f*ck?!
Installing 02 sensors is easy, just unplug the elec. connection and unscrew the old one, install is the reverse.
OnyxCobra is offline
Old 10-20-2006, 04:28 PM
5IVE.OH
5IVE.OH's Avatar
yuor engrish not soo gooder
5IVE.OH is offline
Old 10-20-2006, 04:30 PM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: 5IVE.OH
LMFAO!!!
Old 10-20-2006, 04:35 PM
TwotoneVert
TwotoneVert's Avatar
I recommend getting the socket they make that has the cutout for the wiring harness. Makes it lots easier than a wrench, and dont forget anti sieze on the threads.
TwotoneVert is offline
Old 10-20-2006, 04:45 PM
mustangtt89
I now how install O2 sensors
What I ask how you install AFR gauge
Old 10-20-2006, 04:46 PM
mustangtt89
So what my English is not good
Old 10-20-2006, 04:47 PM
hellas85stang
hellas85stang's Avatar
i wanna know if the air fuel gauges are good and any1 running them if so are they acurate
hellas85stang is offline
Old 10-20-2006, 04:50 PM
88BlueGT
88BlueGT's Avatar
Well, the only places you are going to get a AF ratio gauge is from an aftermarket companies and most gauges from aftermarket companies are pretty good.... if you go with an autometer setup it will be great.
88BlueGT is offline
Old 10-20-2006, 04:54 PM
TwotoneVert
I have a glowshift, and it works just fine, it is accurate as far as I can tell. Intstallation is pretty straight forward, power, ground, and one wire will need to tap the return signal wire from the sensor.
Quick Reply: Air Fuel ratio gauge
