Fox body/LS1 conversion..
#31
RE: Fox body/LS1 conversion..
ORIGINAL: Jasperstang308
how much would something like that cost? like motor trans and wiring harness? and then what about the clutch set up would it all be chevy or ford? and then what about the driveshaft and various mounts? are they any kits for a swap like this?
#32
ORIGINAL: PRO50SC
I'll take that bet!!!
ORIGINAL: JD1969
I am willing to bet that you will not get flamed on LS1tech about this subject.
#33
i have a 347 stroker with a crap load of money in it and i am hoping to be at a STOCK thats right i said it i am hoping to me at a STOCK ls1's hp.
#34
ORIGINAL: HC_CrAzYHoRsE
no offense, but if you're hoping to put out 290-295rwhp out of a built 347 with a crapload of money in it... there's a problem right there. most people put that out with an H/C/I 302.
#35
for my conversion i know a guy that will make me a standalone harness from a actual harness. then all youll need is 3 wires to fire the LS1 in any chassis. how do you think i did the LS1 in the 240? so for 500 bucks you have a harness that only takes 3 wires and then the rest can be for gauges and etc....very simple plug and play
for the drop out and modified harness about 3000 to about 5000 depending on the combo that includes the trans depending on T56 or 4L60e, accessories and etc. everything you need to do the swap
and for that price you dont really get much of a stang. granted you can make some power then you need a trans that will hold the power then honestly the 302 block isnt that strong so now you got a weak point.
plus its very very very easy to see 30mpg out of a ls1. buddy went 12.8 consistant with nothing more then a SLP SS with my own custom tune with full leather and etc, sway bar connected and got 30mpg with the A/C on.
now you can say you can make a 302 into something strong yes you can. youre not tellin gme nothing i dont know but for the price its not worth it.
now if you wanted to put a joke SBC in it i would laugh but LSX anything is pimp plus you get a motor that doesnt weight much. its about 200lbs lighter then your typical 302 motor
#36
allright!!! everybody put down the wrench!!! ...this just in "it is not worth it to mod your 302!!" everybody go out and get yourself an LSX motor!!.... never mind that a 1500$ H/C/I and 2000$ S/C set-up with 1000$ in supporting mods will get you over 500rwhp, that's just weak and too costly.... get a 5k headache LS1 swap instead and put out 300rwhp!!! it's much better!!!
thank you Quik for showing us the way
#37
ORIGINAL: HotWheels347
#38
you do know that around mid 4xx the block likes to spilt dont ya?
you have no idea who your talking to and lets not make this a pissing match...im not really in the mood to school ya tonight
#39
ORIGINAL: Quik
dude dont even start.. if you can make 500rwhp from a 302!! ill reinburse you if you have all reciepts. the key is it has to be NA and last for atleast 5k in miles.
My friends Turboed 342 put out 575 hp at 5800 rpm. It saw many many many track and street passes. Also won the FFFD in Fontana in 2003. What killed that motor was a bent crank. And that was over a year of thrashing it.
Sure the LS1 motor is better. It is about 13 years newer techonolgy and bigger displacement. However I can take my stock 302 and put 500 dollars in it and break off an LS1 anyday of the week with a 17 year old, 120,000 mile, smaller displacement, older technology motor.
#40
ORIGINAL: Quik
