347 Hp estimate
Old 10-28-2006, 12:32 AM
ltrayne84
ltrayne84's Avatar
Default 347 Hp estimate
ok guys, like i said i'm going to dyno tune my car in the coming weeks... so i just want to see how good ya'll are at estimating Horsepower. And if you want you can throw out an estimated 1/4 mile time too.
Here are my mods:
347 stroker, 3.55, Tremec TKO 600, tri-ax short-throw, 1 3/4" bbk shorty chrome headers, MSD 6AL, 9mm ford racing wires, ported GT-40 heads, block bored .30, H-series main bearings, H-series rod bearings, crane 1.7 rocker arms, trickflow stage 1 cam, ported cobra intake, 10.5 aluminum pistons, kmotion valvesprings, 50 oz Romac Balancer, 76 mm throttle body, CL cold air intake, hi flow water pump, hi volume oil pump, motocraft distributer and plugs, crane cam blaster coil, 3 row aluminum radiator, 15" black magic electric fan, Ford Racing underdrive pullies, 23 tooth speedo gear, bbk caster camber plates, coil over springs, koni road race shocks with adjustable front struts, lowered 2 inches, saleen suspension parts, Megabite upper and lower control arms, Saleen lower control arm brace front, tri-subframe braces, panyard bar system rear, global west subframe, 225-lpm fuel pump, Ram heavy duty clutch, Optima 900 CCA red battery, dual 2.5" turned down pipes and 2 chamber flowmasters
i think thats it... so let me see some numbers
ltrayne84 is offline
Old 10-28-2006, 12:59 AM
FullAuto
FullAuto's Avatar
Default RE: 347 Hp estimate
335rwhp 375rwtq
FullAuto is offline
Old 10-28-2006, 01:08 AM
grabbem88
grabbem88's Avatar
i doubt that much tq....
grabbem88 is offline
Old 10-28-2006, 01:12 AM
03BottleFedGT
03BottleFedGT's Avatar
345 horse and about 380 torque
03BottleFedGT is offline
Old 10-28-2006, 01:14 AM
grabbem88
grabbem88's Avatar
with ported heads and the stageI cam....290/340
Old 10-28-2006, 10:18 AM
ltrayne84
ltrayne84's Avatar
grabbem88 Date 10/27/2006 11:14:38 PM
^^^Are you kidding me!?^^^^ I'm well over that.. [sm=trust_me.gif]
Old 10-28-2006, 11:47 AM
2 kwik
I ♥ Acer
2 kwik's Avatar
296/400
2 kwik is offline
Old 10-28-2006, 12:50 PM
grabbem88
grabbem88's Avatar
post up the numbers
Old 10-28-2006, 12:57 PM
mustangfxbdy
mustangfxbdy's Avatar
320/370
just because of heads and intake i think if you were running better heads and intake numbers would be alot better. but post em up im very interested
mustangfxbdy is offline
Old 10-28-2006, 01:14 PM
7upedition
7upedition's Avatar
300/335 to the wheels, i dunno seems close[&:], interested to find out
7upedition is offline
Quick Reply: 347 Hp estimate
