no start no spark...more info
Old 10-28-2006, 04:22 PM
  #21
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: no start no spark...more info
yup
PRO50SC is offline
Old 10-28-2006, 04:23 PM
  #22
fourfivefour
fourfivefour's Avatar
Is your ignition module on the distributor or is it remotly mounted? Did you change the module already?
Connect a test light to the battery positive and check the negative wire at the coil while cranking. Does the test light blink?
fourfivefour is offline
Old 10-28-2006, 04:26 PM
  #23
Idrum88
Idrum88's Avatar
ok i just tested the tan wire to the coil while cranking and it stays at .5v
and yes its independent mount under the CAI......and what do u mean by testing the coil???
Idrum88 is offline
Old 10-28-2006, 04:28 PM
  #24
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: fourfivefour
That would explain if it wasn't replaced along w/ the coil. I just assumed it was a dizzy mounted ICM.
PRO50SC is offline
Old 10-28-2006, 04:30 PM
  #25
Idrum88
Idrum88's Avatar
ORIGINAL: PRO50SC
ya i already replaced the ICM but i just did what u said with the coil and theres only .5v coming out the other side while cranking
Idrum88 is offline
Old 10-28-2006, 04:32 PM
  #26
fourfivefour
ORIGINAL: Idrum88
The two wires at the coil power plug. Key on one should have 10+ volts. Test the other wire with your test light (NOT dvom) connected to battery + positive while cranking the engine does the test light blink?
Old 10-28-2006, 04:38 PM
  #27
Idrum88
Idrum88's Avatar
ORIGINAL: Idrum88
i have no idea what u mean by this touch the positive end of the battery with the light>??????????????
Idrum88 is offline
Old 10-28-2006, 04:44 PM
  #28
fourfivefour
PM me your phone number and I will call and walk you through the testing. Mike
Old 10-28-2006, 04:48 PM
  #29
Idrum88
Idrum88's Avatar
ok PM sent
Idrum88 is offline
Old 10-28-2006, 05:00 PM
  #30
threeg502
threeg502's Avatar
You have two wires coming out of your coil right? Well one wire is for power and the other is for ground. You won't see power on both wires. "Ground" as we call it is the same as touching the negative battery cable. It is just done that way to save wire and keep things neat.
threeg502 is offline
Quick Reply: no start no spark...more info
