OK to use stainless header bolts on aluminum heads?
RE: OK to use stainless header bolts on aluminum heads?
ORIGINAL: jsklx50
No, they arent rusted on the threads. Its the heads that are rusting so I want to replace them with something that wont rust just for looks.
no way....stainless bolts are mostly grade 5 bolt unless noted also with heat cycles then tend to corrode and become very hard to loose and break..we have this problem with tobacco machine we sent to china
ORIGINAL: Sidewayz6.0
The stuff that stops hair from growing???
ORIGINAL: PONY GUY
Mixing stainless with aluminum will cause electrolasis (<--spelling is off)
thought that was Nair????
just get some Black anadized header bolts and change them or get some high heat paint and just repaint the bolt heads
I spoke to a representative from ARP today and he said the stainless ones do cause a chemical reaction but not if anti-seize is used. He said that is why anti-seize should always be used on spark plugs in aluminum heads. I bought the stainless header bolts.
Luke9222
10-22-2015 11:55 PM
09-10-2015 08:39 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
