Are Edelbrock heads decent?
Old 10-30-2006, 03:09 PM
88blackgt
88blackgt's Avatar
Default RE: Are Edelbrock heads decent?
what about vic jrs, or are they not emissions legal
88blackgt is offline
Old 10-30-2006, 03:12 PM
grabbem88
grabbem88's Avatar
as long as eddy has an E.O. number then they are legal
grabbem88 is offline
Old 10-30-2006, 03:32 PM
chath_brick
chath_brick's Avatar
there was a guy in another thread who said he actually got better numbers with edelbrocks than AFRs...i dont remember who it was though.
chath_brick is offline
Old 10-30-2006, 03:33 PM
88BlueGT
88BlueGT's Avatar
Edelbrocks are not bad heads at all .... there are alot of companies out there besides AFR... believe it or not!
88BlueGT is offline
Old 10-30-2006, 03:36 PM
PX429
PX429's Avatar
Depends on your application. Edelbrocks can give you more power then AFR's it just depends on what size heads you buy and what mods you have.
PX429 is offline
88blackgt
88blackgt's Avatar
out of the box the afrs will outflow the eddy vic jrs by a little, but after some porting they flow as well as the larger afrs. and for the price, could very reasonably get the vic jrs and port them for the same/less money than a set of afrs.
Old 10-30-2006, 10:36 PM
hellas85stang
hellas85stang's Avatar
for the$ i bought rpms and had ported i flow more air,and more avg air then afrs and i had 165s and 185s b4 there great..to say there better then edelbrocks id say depending on set up...at selfs racing here we put rpms on after afr165s and gained a few hp....
hellas85stang is offline
Old 10-30-2006, 10:45 PM
ZachW04Stang
ZachW04Stang's Avatar
ORIGINAL: 88blackgt
Where did you get that from? Edelbrock victor jrs will flow all the way up to 7500 rpm right out of the box on a 302. Afr 185's which cost more won't flow that high up. The afrs will make more down low power but if your building a pure power beast the victor jrs would be the way to go.
ZachW04Stang is offline
Old 10-30-2006, 10:46 PM
Smokinrubber
Smokinrubber's Avatar
stay far away from victor jr ..pro comp ...eldebrock .. they dont flow ,so there for they make no power ..go with afr 165 or 185
Smokinrubber is offline
Old 10-30-2006, 10:48 PM
88blackgt
88blackgt's Avatar
it was in an article that tested high end sbf heads. im confused are you disagreeing, because then you go on to support the original conclusion
Quick Reply: Are Edelbrock heads decent?
