bumped timing
bumped timing
if i bump timing to lets says 14* would i have to put in better gas. and what kinda gains will i see? and also how and where do i adjust the shift points for my auto tranny? thanx in advance.
RE: bumped timing
With bumped timing its always better to run higher octane. The higher the octane the more its resistant to detonation (spark knock). When you bump the timing, the further you advance it the longer the gas needs to burn, higher octane takes longer to burn than lower octane. so in essence if run a low octane gas with bumped timing itll burn too quickly and ignite before it should, causing detonation.
-P.
PS: I run 93 all the time, 14* timing
-P.
RE: bumped timing
^ how bout WOT? you do know that at WOT the computer will add up to 16* of timing to adjust for a/f ratio right? that seems pretty high though for '87, but each car has its own taste of the petro...
