Question... don't get mad
RE: Question... don't get mad
You should also check out this sticky.... it will help you with alot when people are talking about things and you are not exactally sure what they are talking about.
https://mustangforums.com/m_563238/tm.htm
heres a few pics that help see how the heads fit in with the rest of the motor when its out
[IMG]local://upfiles/51223/F2C22A317B6444F78973FD4C85B38E5E.jpg[/IMG]
[IMG]local://upfiles/51223/156168B063BF4435833A291DD5F703C8.jpg[/IMG]
lol thanks mike hawke for recommending that site... it explained things about a internal combustion enigne prety good and i under stand a bit more about how to engine works
so each on those springs on the head are the lifters for each cylinder which open the intakes right? you put a valve cover on those to protect them from getting kit and knocked around and screwed up a cycle. and inside the actual engine below the heads in where each cylinder is?
the spring is a valve springs, a cam lifts the lifter with a pushrod in it, which pushes up the rocker, then pushes down on the valve (opens), the spring holds up (closed) the valve.
Yes, the cylinders are below the heads.
[IMG]local://upfiles/24448/AE68454F746A4305BE5F545BBAAF845A.jpg[/IMG]
and a head gasket just seals the area between the engine and the heads so its air tight? if so why are they so expensive to replace? because you have to take alot of the engine apart?
http://auto.howstuffworks.com/engine.htm
http://auto.howstuffworks.com/camshaft.htm
try those, they explain it fairly well
Yes, head gasket is between the head and the block. There is alot of pressure inside of those cylinders, and they heads are torqued down very tight, therefore a gasket makes a seal so no pressure is let out. If you blow a head gasket, then you lose compression most of the time, or i should say, some compression, therefore you lose power.
ORIGINAL: Braydon619
