what heads are these?
Old 11-01-2006, 08:43 PM
philthy89fifty
philthy89fifty's Avatar
Default what heads are these?
my friend bought these heads off ebay and they were suppose to be gt40's not p's but they have no smog holes. i think they might be 2 diferent heads. can you guys check em out these are the castings he gave me.
head #1 - 13j5
head #2 - 5e26
philthy89fifty is offline
Old 11-01-2006, 09:07 PM
Nadelle
Nadelle's Avatar
Default RE: what heads are these?
aww man thats a good question. I looked for those casting numbers but didnt get anything, my next step would be to call a ford parts suplier.
Nadelle is offline
Old 11-01-2006, 09:08 PM
threeg502
threeg502's Avatar
Ford part numbers would start with E7TE, OR D5TE
The E7 is the code they used for 1987. E meant it's 1980 something. The 7 was for the 7 in 1987.
D7 would be for a 1977.
F7 would be for 1997. It's a fairly simple pattern as far as that end of it goes.
So my point is the numbers you have aren't helpful. Look for numbers that begin like the ones above.
I think they'd be stamped rather than cast in.
threeg502 is offline
Old 11-01-2006, 09:27 PM
SKEETS50
SKEETS50's Avatar
ORIGINAL: threeg502
I work for ford and what you said is wrong bro. Are there any other numbers or letters on them????
SKEETS50 is offline
Old 11-01-2006, 09:31 PM
threeg502
threeg502's Avatar
ORIGINAL: SKEETS50
ORIGINAL: threeg502
Then what are your insights to the world of ford?
Old 11-02-2006, 12:00 AM
philthy89fifty
these are the numbers he gave me. do all gt40 heads come drilled for smog can these be from a lighnting.
Old 11-02-2006, 05:16 PM
philthy89fifty
also one head says "hancho de mexico" the other one does not. so again do all true gt40's (non p) have provisions for smog? these heads have the 3 bars on the front. also when we tried to bolt up the 1.7 rockers i gave him, they did not fit, the pushronds on some lifters were not lomg enough and had 1/4" play while others were fine. we put back on the e7's because of the smog thing and all the rockers adjusted and torqued down even and without incident. what gives?
Old 11-02-2006, 05:20 PM
88BlueGT
88BlueGT's Avatar
Philthy... are those 17 or 18' wheels on your car?
88BlueGT is offline
Old 11-02-2006, 05:22 PM
5speed GT
5speed GT's Avatar
my 1996 explorer gt40's did NOT have holes for the smog tube on the back
5speed GT is offline
Old 11-02-2006, 05:33 PM
philthy89fifty
^ that sentence helped me out a great deal thank you.
my wheels are 18x9 my tires are 245/40/18 goodyears.
Quick Reply: what heads are these?
