Need Help....
Need Help....
OK well i just got this mustang for ridiculously cheap, but there are problems. Its a 95 5.0 vert
-Well for one cold starts REALLY affect this car... but i had a dakota i dropped a 340 in and cold starts werent great for that either
-My next one, when im driving in any gear the car loses power at 2500-3500rpm depending on the gear. If i go wide open the car will sputter and rpm will not raise and i wont really go any faster than what i already am at WOT. There is one spot on the throttle where everything runs smooth, thats about half throttle, if i go anymore the rpms raise and lower and drop a raise and the car sputters. And this is through any gear. It makes it very hard to accelerate into traffic. Im not sure how great i explained it to well
1st gear- hold it a half throttle will accelerate fine untill about 3000rpm then starts sputtering
2nd gear- same as 1st, if i go full throttle it will lose power and sputter untill i go back to half throttle
3rd gear- same as 2nd but can go till about 3500 before sputtering, same happens at full throttle untill half
4th gear- same as 1,2,3 still about 3000-3500rpm before sputtering, same happens at full untill half
5th gear- Considering the previous gears, i dont get up to a high rpm. But the same thing applys to the full throttle and half throttle
ALl gears shift fine and when its cruisin is sound AWESOME. I WANT TO DO A BURNOUT DAMNIT. just one is all i ask.
thanks guys
thanks guys
RE: Need Help....
I havent really changed anything ive had the car for 2 days and have had school. ONly time i drive it right now is at night. Im tryin to see what could be wrong with this car.
I need new air filter
cap
rotor
plugs
wires
Im sure an oil change
im sure i need to clean the Throttle body
Clean Maf
Clean IAC
What do i use to clean the IAC, MAF and what to cheak the TPS... WHere is it
cap
rotor
plugs
wires
Clean Maf
Clean IAC
RE: Need Help....
I think it has a bad ACL or MCL. But for real just take the intake off the trottle body and clean everything with carb cleaner, also the mass air meter. Check voltage and then you should be rocking!
