OBD I or II?
Old 11-05-2006, 06:08 PM
Joel5.0
Joel5.0's Avatar
Default RE: OBD I or II?
ORIGINAL: 95hooptey
My 95GT has an OBD II.it was made at the end of 95 right before the modulars came out.
[sm=nono.gif]....It has the OBD-II connector ....but is not functional, ALL '94-'95 5.0L are OBD-I........5.0L OBD-II systems are only found on the Explorer/Mountaineer trucks.
Joel5.0 is offline
Old 11-05-2006, 06:37 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: 95hooptey
Both 94 AND 95 stangs have OBD-II ports, due to Ford using the same in-car harness in the GT/Cobra as the V-6
AdderMk2 is offline
Old 11-05-2006, 08:21 PM
musclemustang94
musclemustang94's Avatar
Your car is OBD 1 it just has an obd2 connector. OBD1 on the 94 and 95 mustang was pretty much obd2 it does all the same things it just has a diffrent connector. My 94 has an obd 1 port under hood but an 0bd2 port in the car. yours probably has the same thing.
musclemustang94 is offline
Old 11-05-2006, 08:40 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
i have a 95 cobra mustang and it has obd2 i kno for sure i went ot get hte codes read like 30-45mins ago... guy said it should have been obd 1 tho... but the ****ing reader was broken or sumthan... so i dunno whats wrong with my car
CrazyCobraSpeed is offline
Old 11-05-2006, 08:44 PM
PX429
PX429's Avatar
ORIGINAL: CrazyCobraSpeed
read slowly what we wrote earlier!!![&o]
PX429 is offline
Old 11-05-2006, 08:53 PM
CrazyCobraSpeed
ok were is the obd1 plug in that is fun****ail then??? cuz i didnt notice another one under the dash or under the hood... cuz i need those codes so i know waths wrong with it
Old 11-05-2006, 08:54 PM
PX429
PX429's Avatar
under the hood, behind the passanger shock tower
PX429 is offline
Old 11-05-2006, 09:01 PM
Ninety5five0
Ninety5five0's Avatar
I was thinkin about this today at work, i was wondering what i had, but now i know. Thanks....fellas.....
Would there be any perks of gettin a scanner for my car ? Or should i not waste my money and just take it to the parts store and have them run it when it goes on ( i work there too ) ?
Ninety5five0 is offline
Old 11-05-2006, 09:11 PM
CrazyCobraSpeed
cool ill have to go bak to autozone and call then dumbasses lol... ok im not that mean... thanks for the info tho helps out a lot... anyone recommend any specific hand tuner by the way... i assume a hand tuner would plug into this obd1 plug in..??
Old 11-05-2006, 09:23 PM
Joel5.0
Joel5.0's Avatar
'94-'95 Stangs OBD-I/EEC-IV has a "datastream" capability (as other post-'90 Ford EEC-IV's). A scanner with the datastream option, will allow you to see real-time the different sensor output readings live. To access the codes, the jumper method is "done" by the scanner......BTW, the following engine bay diagram shows the location PX429 mentioned...labeled as Data Link Connectors (DLC)....
Joel5.0 is offline
Quick Reply: OBD I or II?
