MY SIGNAL LIGHTS WONT WORK
RE: MY SIGNAL LIGHTS WONT WORK
Hi Raul, if you havent fixed the issue yet maybe you could check the ignition switch. I know it sounds strange but friend of mine had the exact same issue on his 89. He was also having problems with the car dying out at random times. We went through his ignition and checked all fuses eveyrthing was fine. Sometimes when he would put his key on accessory the blinkers would work. We took the plastic pieces off of the column and i pushed the leads and the switch fell apart :O. Haha good luck.
