Oil capacity on 5.0?
RE: Oil capacity on 5.0?
I dont wanna sound like an ***, but you are checking and filling your oil level on level ground right? Don't mean to offend but there are people out there that you just cant assume the basics with.
This may help. On my car, the dipstick appears to be about a quart or more off. It confused me at first, until I figured it out. So what I did was, after an oil change, I drove the car and parked it on level ground (in the garage). Then I came back a couple hours later and read the dipstick. At the point at which the oil read on the dipstick, I took a knife and carved a line across the stick, representing full. Now every time I change my oil (with 5 quarts, which I know is correct), the oil level comes to that point. Assuming that you pulled both drain plugs, and changed the filter, I suggest that you do the same thing.
ORIGINAL: 88BlueGT
no matter what your dipstick says?
