weird noise when braking from the rear.
It just might be my brakes, they already squeal but now when i am braking i feel like its wobbling or something from the back right tire?
RE: weird noise when braking from the rear.
a couple of things might be the cause...parking brake grabbing/not releasing...fluid low? cause the proportion valve will compensate this by putting the load on the front brakes....what i think it is...is the inner wheel bearings
sounds like a broken spring inside the drum, or an incorrectly installed spring. loose shoes will cause a vigorous shake when activated if the springs aren't right
check lug nuts?...make them fix it.
ORIGINAL: Black95MustangGT
i just put my 4 new tires on my car, Pep Boys did it for me, and it started doing it about a couple days afterwards.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
KingRando
10-01-2015 11:16 AM
