need new suspension...any ideas?
Old 11-07-2006, 02:39 AM
89regattaLX
89regattaLX's Avatar
Default need new suspension...any ideas?
I need a suspension setup that will let me launch well, take corners like nothing and won't spin tires when the road is damp...any suggestions? btw, I'm just looking for a mean street machine not a dedicated racer or anything so I don't need an expensive adjustable setup.
89regattaLX is offline
Old 11-07-2006, 02:44 AM
dimebag
dimebag's Avatar
Default .
it sounds like to me you want two diff set ups... usually if you can launch really good then cornering will suck. and if it handles like a ****... then your launches will suffer... sounds like you should go w. something more for handling... as w.e. you get, it should launch better than stock... so long as you dont drop it to the ground...
as far as brands, check out www.50resto.com most of the stuff they have is dependable/good products...
dimebag is offline
Old 11-07-2006, 02:47 AM
I3atR!ce
I3atR!ce's Avatar
Default RE: .
just put mine in... urp u/l control arms, eibach lowing springs in the back... tokico illumina S/S with front d&d coil overs and eibach front/rear swap bars.... god it feels nice, launch way harder/ and corner like crazy.... on and i have MM SFC and 4 point k member brace... haven't up the strut tower brace in yet.
I3atR!ce is offline
Old 11-07-2006, 03:00 AM
89regattaLX
Default RE: .
I'm not looking for 2 differant setups, like I said it's a street machine so my main concern is handling and cornering but any improvement on lauch over stock is a plus
Old 11-07-2006, 03:05 AM
dimebag
dimebag's Avatar
Default RE: need new suspension...any ideas?
ORIGINAL: 89regattaLX
thats what i meant... you cant accel alot in each, its one or the other... i agree that if its a street car, and cornering is your bigger concern then go for that, like said before... anything should launch better than stock, so go ahead and focus on handling... unfortuanitly i dont know much about handling suspension packages that are out there, as i am going with more of a drag set up... but im sure some one else is on the same page as you and will be wiling to help.
dimebag is offline
Old 11-07-2006, 03:21 AM
89regattaLX
that's cool man, I appreciate any advice I get
Old 11-07-2006, 10:21 PM
89regattaLX
does any one know of any good brands?
Old 11-07-2006, 10:23 PM
grabbem88
grabbem88's Avatar
strange shocks/struts eibach springs sub frames upper/lowers
grabbem88 is offline
Thunderball
15
11-22-2015 11:49 PM
Sixer4Life
10-12-2015 04:26 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
marc954
09-29-2015 11:18 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: need new suspension...any ideas?
