Speedometer Recalibration Gear 83-93
Old 03-27-2005, 12:10 AM
  #21
5Liter Import Eater
5Liter Import Eater's Avatar
Default RE: Speedometer Recalibration Gear 83-93
I just got my new 3:73 gears installed and i know the speedometer is off but in your list it doesnt mention the gear for a 93 5 speed 3:73. and also where does the gear get installed at?
5Liter Import Eater is offline
Old 04-12-2005, 12:22 PM
  #22
SilverHorse
SilverHorse's Avatar
ORIGINAL: Stinger
Hey how about 3.73 for a 5 speed /1991?LOL
I am pretty sure you will use the same gear that works in a 87-89 with 4.10's!
call these guys, they are great, and they seem to know a bit about the cars too!
www.50resto.com
Ok, well, after researching before posting ::always good::, I found that the white gear, which is 23 tooth is good for your car with 3:55's.... give those guys a call, they can help...
SilverHorse is offline
Old 04-12-2005, 02:44 PM
  #23
Magiarn71
Magiarn71's Avatar
It depends on your tire size too (EX. you need to change your speedo gear if you keep your rear end gears the same and change tire size). If you changed the overall diameter of your tire from stock, you cant use a chart.
http://www.mindspring.com/~steveflye...ear_select.htm
Magiarn71 is offline
Old 05-02-2005, 11:24 AM
  #24
hawkwitastang
hawkwitastang's Avatar
I've got the stock transmission for my year which is a 4 speed srod, kida outdated and not working at the moment since my rearend went out on my friday but I've got 14" rims with 60's on them and I'm going to put in 3.73 gears any idea what I might need? My speedo is already off by about 5mph over. Thanks
hawkwitastang is offline
Old 08-04-2005, 03:49 PM
  #25
house302
house302's Avatar
is there one for 3.90 gears
house302 is offline
Old 08-18-2005, 03:55 AM
  #26
MattCA
MattCA's Avatar
how do you recalibrate gears? i just bought a 1990 mustang 5spd today and we noticed that the speedometer is off. it has 3.73 gears so now i know why its off.
MattCA is offline
Old 08-18-2005, 07:44 AM
  #27
Speed_racer
Speed_racer's Avatar
I have a question im running 2.73 gears with 245/45R17's on a 95 mustang gt. Wat kinda speedo gear should i have?
Speed_racer is offline
Old 08-19-2005, 03:13 PM
  #28
Speed_racer
Hahaha... I mean 3.73 gears not 2.73. Silly me
Old 08-19-2005, 05:44 PM
  #29
MattCA
MattCA's Avatar
some guy is going to correct mine today. the gear is only $25 from the dealer. but i think he gets a discount because he used to be a mechanic there.
MattCA is offline
Old 01-04-2006, 09:23 PM
  #30
95_302_StangMan
95_302_StangMan's Avatar
How about a 95 w/ t-5 and 3.73's?
95_302_StangMan is offline
Quick Reply: Speedometer Recalibration Gear 83-93
