TPS Voltage problems
Old 11-12-2006, 06:23 PM
Jared_blown5.0
Jared_blown5.0's Avatar
Default TPS Voltage problems
I tried setting my tps voltage and couldnt seem to get it under 1.2's. So i went and bought a brand new one, and I cannot seem to get it to under 1.16's without turnoing the throttle body screw way out. When i do that however the car cant even idle because it so far out. What do I do tho fix this?
Jared_blown5.0 is offline
Old 11-12-2006, 06:41 PM
fourfivefour
fourfivefour's Avatar
Default RE: TPS Voltage problems
You may need to slot the holes in the sensor to get the extra adjustment.
fourfivefour is offline
Old 11-12-2006, 06:50 PM
Jared_blown5.0
i did that in the old one, and didtnt work, now i have a brand new on.....
Old 11-12-2006, 07:06 PM
fourfivefour
Try adjusting it with the screws out and you will find out how far off the holes are.
I have heard of drilling a 1/8" hole in the throttle plate to raise the idle. Doing that may allow you to close the throttle plate and still have enough idle speed and get the proper TPS voltage.
Old 11-12-2006, 07:08 PM
5.0stanger
5.0stanger's Avatar
You need to reset your base idle, and slot your tps holes to get it within range. What throttle body are you running?
5.0stanger is offline
Old 11-12-2006, 07:26 PM
Jared_blown5.0
bbk 70 mm
Old 11-12-2006, 07:30 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
who ever is telling you that doesn't know **** drilling a hole will only help with idle on car with large injectors in needing a lil more air..it has nothing to do with the TPS
ORIGINAL: fourfivefour
2 kwik is offline
Old 11-12-2006, 07:42 PM
Jared_blown5.0
seriously drill a hole in the tb blade? 1/8" and where do I drill it?
Old 11-12-2006, 07:44 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
the hole won't help the tps
2 kwik is offline
Old 11-12-2006, 07:47 PM
Jared_blown5.0
will it help my surging idle? it goes from 1400 to 500 and stalls a lot of times
Quick Reply: TPS Voltage problems
