Running Rich? by Mattdel
first sn95 please help
First off ive only owned foxes wanted to step up for a smoother ride since its my everyday driver first yr when bought it passed emmisions i have headers and no cats but still smog pump when it got cold this winter i noticed that when i turned on an excessery sutch as lights or high speed heater my volt guage would move never did this befor also if i drive for more then 30min my volt guage will go to the low side of the m when this happens my temp guage tweeks and my oil guage needle goes way high as well in past three mo ive replaced bat alt twice coolent temp sencer not one for dash radiator and electric fan controll box behind rad overflow also egr valve and smells very ritch. when on freeway it barely goes of the n on temp guage and idles rough until at normal range of worm at idle but still smells ritch added more grounds as well as checked previouse ones and no stereo no check engine lite on eathier so it shows no codes yes ive cleaned filter mas air meter and sencer on boot and throttle boddie im stumped and my tabbs are due please please help if you know the problem this is getting expensive as well as out rite rediculas miss my fox nice and simple thanks to anyone with imput
You should start a new thread with this problem, that way the people trying to help don't have to read the whole first page of a thread that is many yrs. old.
Before you do that, pull codes first and list them in your new thread.
And no disrespect, but correct spelling and punctuation go along way in people trying to understand the description of your problem.
Good luck
Good luck
