Clutch Pack Shims
RE: Clutch Pack Shims
I might do that friction, steel, friction thing you are tlaking about now. Adder my new steels have 23 teeth...thats weird i didn't realize that. Anyways...No one answered my question lol. I need to know what size shim to use!
ORIGINAL: musclemustang94
ive posted this several times it needs to be stickied. http://www.angelfire.com/theforce/5o...5ohtech001.htm
Yeah, your shim will be different to mine due to wear. I would just reuse the shim that was in there and replace the clutches. When I did mine, that is what I did, it was tight(new clutches) and had worked great.
Question...is there an upgrade for the spring..something stronger?
ORIGINAL: 5.0stanger
ORIGINAL: rsw007
yes, out of a heavy duty 31 spline carrier. just get a spring for say a 94 f150 4x4
Which would be good if you had already done a gear install, cuz then you wouldnt have to worry about re-setting the rear end for a different carrier!
As far as I know, the whole carrier will swap.
