edelbrock heads
RE: edelbrock heads
well if ur on a budget go to the junk yard and pick up a set of gt40's off an explorer and have them ported out and they will flow better than the afr's, thats the best setup u could do, but if u have to have aluminum then i would suggest trick flow heads over edelbrock, they flow better and make more power, but edy's are good heads
RE: edelbrock heads
cool well ill look for either trickflow or edelbrocks, the reason i haven't got any cast gt-40 is the junkyards want between 2 to 4 hundred dollars and porting on top of that ,that is why i am just gonna get a set of aluminun heads
RE: edelbrock heads
ORIGINAL: jtmustang
RE: edelbrock heads
jegs has a nice set of " jegs" brand heads. they have2.02 intake 1.60 exhaust 7/16 rocker studs 5/16 guideplates they say up to .550 lift cam with stock piston notches 58cc chambers and 170cc intake runners aluminum heads for 549 each plus you can use the aftermarket adjustable roller rockers not the stock type pedestal mount
RE: edelbrock heads
ORIGINAL: jtmustang
