Stroker question
Stroker question
I've already decided on 347. I'm trying to build this as radical as possible but still be streetableoccasionally. So here it goes, with 347, AFR 165 heads, vic JR. intake, holley 650 carb, what cam should i run any suggestions? Dont care about idle quality i want it to lope. Also i have 1.7 roller rockers with whatever cams you recommend will the piston to valve clearance be ok?
RE: Stroker question
heads - AFR 205, Canfield 195s, RHS (something comparable), ported TFS TW, Vic Jr.
intake - Victor Jr., Parker funnelweb
cam - www.camshaftinnovations.com
And don't shoot for 11s. Shoot for LOW 11s.
he picked the right carb for the job, that carb is good on the small blocks, if you consider that bbc run 750 to 800 carbs and they have a good 200 c.i. on the 347. the heads i agree wit you but the carb is just the right size
ORIGINAL: FullAuto
You want it radical but you picked a small carb and smaller head.
Put an F cam in it because you're screwed.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
