burning to much fuel...help!!
Old 07-30-2003, 01:04 AM
falconkid4478
falconkid4478's Avatar
Default burning to much fuel...help!!
i was racing my 88gt the other day and when i got over 4 grand it started pooring out black smoke. which i take it is dumping to much fuel into the engine. I have after market upper and lower intake 70mm throdle body and mass air meter as well as a cool air intake. What can i do stop the fuel problem?</P>
falconkid4478 is offline
Old 07-30-2003, 10:42 AM
jeep45238
I ♥ Acer
jeep45238's Avatar
Lean it out (reset the computer).
jeep45238 is offline
Old 07-30-2003, 03:30 PM
stang574
stang574's Avatar
Is the mass air sensor calibrated for your injector size? That can cause excessive fuel useage. Also check and make sure you don't have any exhaust leaks before your o2 sensors. They will read the excess air as not being burnt(lean) and increase the pulse width on your injectors to compensate. Also just a thought you can check resistance through the injector coils and make sure that none of them are shorting out and staying open.
stang574 is offline
Old 07-30-2003, 03:33 PM
stang574
stang574's Avatar
Never mind the exhaust leak check if it only happens at wide open throttle. At WOT the computer dosen't look at the o2 sensors readings for proper air/fuel ratio. But if it happens at part throttle, it could be worth a look.
stang574 is offline
Old 07-30-2003, 05:02 PM
vfast
I ♥ Acer
vfast's Avatar
you need to take care of the leak
vfast is offline
Old 08-01-2003, 03:07 AM
stang574
stang574's Avatar
Sorry for the confusion, I ment that if it only smokes when you got the pedal to the metal, then it probably isn't your exhaust sucking in unmetered air, throwing off your o2 sensors reading.
stang574 is offline
Nurdyguy
02-18-2024 07:58 PM
CS2007
06-25-2019 09:45 PM
lincolnshibuya
12-08-2015 04:37 PM
jhawkr
10-30-2015 01:55 PM
jrrhd73must
10-02-2015 09:17 PM
Quick Reply: burning to much fuel...help!!
