Ok guys If I have around 1500 bux how can I make a stock ho 90 302 400hp
RE: Ok guys If I have around 1500 bux how can I make a stock ho 90 302 400hp
come up with a few more hundred bucks and buy yourself a Trick Flow Top End Kit
http://www.trickflow.com/product/eng...ekits_ford.asp
im not sure you understand HOW MUCH money your gonna need LOL!
with around maybe 4-5,000 you can probably make 400horses, but keep in mind you need to updated the drivetrain(transmission, axles, differential) suspension(torque boxes, subframe connectors, tires) fuel system upgrades(injectors, fuel lines, fuel pump, fuel regulator)
ORIGINAL: 93 LX FiveO
Throw some NX on there and be done with it.
I think you should start building up another motor on the side, here is a shopping list for a reliable 400 horse 302 based motor.
347 stroker shortblock from fordstrokers.com you do not need a forged crank.
HCI call Jay Allen when you are ready to buy and ask for his advice and listen to it.
When it is done and ready, then you need to:
Do subframe connectors/torque box reenforcement
Better clutch or beef up your auto trans/t-5 depending what you have.
Better gears.
If you shop well and do the work yourself you should make it on 5-6 thousand dollars.
Matt
Better gears.
Matt
You're going ot need heads (You can't just port your heads), thats about $1400.. Intakes $500-600, exhaust, probably a bottom end.. Fact of the matter is, to get 400 out of a 302 everything has to be perfect.. Not going to happen with less than 3-4x what you have.. As stated, start building up another motor on the side...
Even if you buy a complete kit by holley/trick flow, for about $2500, that will still put you at about 300hp.
gt40 heads/intake-300
cam/valve train-500
nitrous-500
suporting mods-500
if you spray 150, youll be close if not at/above 400rwhp... bottom end doesnt need modding, btw... this is my set up minus the suporting mods, and i spray 100
cam/valve train-500
nitrous-500
suporting mods-500
