gt40 heads
Old 02-03-2007, 01:22 PM
LIL D
LIL D's Avatar
Default gt40 heads
as i was told to use gt40 heads ported to achieve my goal of 300 rwhp using a e303 cam cobra intake 1.7 rockers 65 mm t body and a 73 mm maf on a 306. but has anyone ever had a valve clearance issue using the 1.7rr with the stock valve size of cast iron gt40 heads
LIL D is offline
Old 02-03-2007, 02:17 PM
90Lxstanger
90Lxstanger's Avatar
Default RE: gt40 heads
I dont think you should have problems, im 100% positive though, good luck
90Lxstanger is offline
Old 02-03-2007, 02:32 PM
africkanV6
africkanV6's Avatar
that will give you 300rwhp?
africkanV6 is offline
Old 02-03-2007, 04:57 PM
burning the tiers
burning the tiers's Avatar
that should give u atleast 310 hp and i would go with a 70mm throttle body incase you did some more work on the car this way theres no restricton if you want more power and so you dont have to buy another one
good luck
burning the tiers is offline
Old 02-03-2007, 05:09 PM
AdderMk2
Banned
AdderMk2's Avatar
1.7's WILL NOT fit under stock valve covers, unless you remove the baffles
AdderMk2 is offline
Old 02-03-2007, 05:41 PM
Hung Like a Stang
Hung Like a Stang's Avatar
can you get the tall style covers? How big of a cam can you go with with 1.7 rockers and GT40's anyone know?
Hung Like a Stang is offline
Old 02-03-2007, 06:17 PM
drhoward
Penis Mod Erator
drhoward's Avatar
can't you just use cobra valve covers, didn't they come stock with 1.7's?
drhoward is offline
Old 02-03-2007, 06:37 PM
LIL D
LIL D's Avatar
i plan on removing the baffles thanks the info guys
LIL D is offline
Old 02-03-2007, 06:41 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
first I doubt it will make 300 rwhp maybe in the 270 range...they make the double like valve covers gaskets for added clearance...
2 kwik is offline
Old 02-03-2007, 06:44 PM
LIL D
LIL D's Avatar
im just trying to get close unless there is something someone else suggests cause i got to keep wit ped mount heads and what kind of bearings and gaskets should i use for my motor
LIL D is offline
Quick Reply: gt40 heads
