gears?
Old 02-11-2007, 04:32 PM
95 BLOWN GT
95 BLOWN GT's Avatar
Default RE: gears?
+1 4.10
95 BLOWN GT is offline
Old 02-11-2007, 04:51 PM
88BlueGT
88BlueGT's Avatar
Default RE: gears?
Im runnning 3.90's in my 93 aod right now, I would of went bigger but I plan on a charger soon. I would go 4.10's or ATLEAST 3.73's. And you will not see a difference in gas mileage between 3.73's and 4.10's. I didnt even see a difference from 2.73's to 3.90's.
88BlueGT is offline
Old 02-11-2007, 05:16 PM
ih8chevy
ih8chevy's Avatar
Default RE: gears?
3:90's at the numerical least. u want anythin numerically higher than that
ih8chevy is offline
Old 02-11-2007, 05:36 PM
ZachW04Stang
ZachW04Stang's Avatar
Default RE: gears?
I think you could get away with 4.30's especialy if you are shifting any higher then 5k with an aod thats n/a. Aods can use a lot of gear to get them going but if gas milage is a concern or you do a lot of highway cruising go with 3.73's.
ZachW04Stang is offline
Old 02-11-2007, 05:45 PM
Twotone93stang
Twotone93stang's Avatar
Default RE: gears?
get some 4.10s thats what i got in my 93 5.0 gt mustang. Its auto also. It was an amazing difference and i like em a lot prolly woulda gone lower if i wasnt doing so much to the car.
Twotone93stang is offline
Old 02-11-2007, 06:22 PM
nitrous_bob
nitrous_bob's Avatar
Default RE: gears?
you'll turn about 3000 rpm's at 80 mph
i get over 21 mpg on my 5-speed w/ 4.10's ac blowing and all
if you go less, you'll be upset you wasted your money
yes there isa diff between trannies, the aod is so horribly geared, you neeed to go higher than you would to make up for the 1st and 2nd gear ratio's
aod 1st = 2.40
t5 1st = 3.35
multiply that by rear gear for total gear , and you'll see a aod car needs 4.10's to equal a 5-speed w/ stock 3.08's in 1st gear
3rd/4th is 1:1 and4th/5th is equal as well about .68:1
nitrous_bob is offline
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: gears?
