How big of exhaust tips and where to buy. Need info asap bassani x pipe to flow master 1 chamber
I am putting a bassani X pipe with cats, flowmaster 1 chamber mufflers all 2.5 inch. I know pretty much nothing about exhaust systems. I want to order the parts tomorrow.
Where can I get exhaust tips that are good quality wont rust, easy to clean etc? I am looking for wide ones that run the same diameter the entire way back. Can I go bigger then 4'? I cant fing them every where and dont even know what size length to get?
I finally found someone to put the system on most mufflers places wouldent give me any info and just told me get the parts and make sure they fit then we will put them on.
Any help is GREATLY appreciated. I want to order the stuff tomorrow.
Are the 1 chamber flow maters the 10 series?
I picked this combo because a guy had a 96 svt cobra and it was the best sounding stang I ever heard. Im hoping to get a very similar sound.
RE: How big of exhaust tips and where to buy. Need info asap bassani x pipe to flow master 1 chamber
should I just put the 1 chamber flow masters on? His car sounds really good. I have a 94 stock mustang GT 5.0 HO. What will be the difference between an x pipe and flow master one chambers and stock pipe and flow master 1 chambers?
http://www.autoanything.com/exhausts...A2453A0A0.aspx Im looking for tips like this. If im running 2.5 pipe do I need a 2.5 opening? Can I go 4 inch tips? What length? Thanks for the help
i have 1 chamber flows on my 99 cobra, the 2 chambers sound louder on a gt for some reason. But yeah order them from summitracing.com
ORIGINAL: 1911A1
also, check out our exhaust thread in the stickies
https://mustangforums.com/fb.asp?m=2677895
Do you have any pics? I want it to look good. What length do you have? I want them to fit right and not stick out the back far.
AdderMK2 wow your car sounds pretty good. Whatkind of exhaust are you running. Would a basanni X sound similar to yours going to 1 chamber flow masters.
