MAP Sensor Vacuum Line
RE: MAP Sensor Vacuum Line
Wow - 2.5 years on one post.
I could use a little help here. I put a '91 5.0 with minor mods into the '86 - speed density.. Since going back to the 19 lb injectors, the car falls flat under any load - it idles nice butstruggles when you gun it. It is near impossible to drive without it dying. I have swapped out the following trying to diagnose the problem: distributer, cap, rotor, wires, plugs, injectors, fuel filter, fuel pump, fuel pressure regulator and the computer. I have checked out the TPS and adjusted timing to try to cure the issue, but the problem persists. Someone suggested a problem with the MAP sensor. As I understand it, there is a vaccum line from the back of the upper intake to the sensor. Is this the only vaccum line going to this sensor?
Also, if anyone has any additional ideas, please let me know. I replaced the coil when I installed the enigne, so I am at a loss as to what is causing the problem.
Thanks
Thanks
jwog666
12-27-2021 08:09 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
