what is thebmaximum MAS flow for 70mm TB
i think my mass air sensor is gone out because while running at the track last weekend my mass air sensor came unplugged and the car was bogging. it was bogging last two track runs even after i cleaned the mas. when it came unplugged i plugged it back in and still it made no diffrence in performance or idle, it just would bog out if i shifted too fast into the next gear, wouldnt bog if i shifted slow. will these sensors go bad and if im running a 70mm TB by holley what would be the maximum flow to run when i get a new TB. with the bog the best pass was a 12.89 at 106mph in the 1/4. thats weak for the mods i have dont you guys agree!!!
RE: what is thebmaximum MAS flow for 70mm TB
ORIGINAL: 2 kwik
and what was used to clean the maf?
it's possible but one's I have go on me would cut my power in and out..every time I would hit a bump in the raod the car would cut out for a sec..thus why I tap them with my finger to check them..
are u running a C&L CAI and maf???... its jsut a wild guess but it you are then get sumthing else... pro m is good... or like a ford lightning maf... all good mafs there
