warm/cold doestn matter
Old 02-11-2007, 12:05 AM
dv3
dv3's Avatar
Default warm/cold doestn matter
sometimes my car doesnt wanna run it just acts like its struggling to get gas......but i dunno if thats it ,...it ocrrects itsekf w/in a couple mins tops....what could cuase this?
dv3 is offline
Old 02-11-2007, 12:08 AM
silver91gt
silver91gt's Avatar
Default RE: warm/cold doestn matter
plugged fuel filter, low on gas, bad fuel pump
silver91gt is offline
Old 02-11-2007, 12:11 AM
90Lxstanger
90Lxstanger's Avatar
is this just when its cold? b/c most likely its cuz the engine is freezing, i think everyone's car is doing this around this time of year.
90Lxstanger is offline
Old 02-11-2007, 12:13 AM
silver91gt
silver91gt's Avatar
ORIGINAL: 90Lxstanger
mmmm, read title
and mine has no problems, and i dont even have a block heater.
and it gets -35 here
Old 02-11-2007, 12:17 AM
90Lxstanger
Mine chokes out like hell when its cold, if the engine temp is under around 150 still it cuts out and ****, as long as i let it warm up 5 mins. its fine, i am runnin a SD systm though, i think a MAF system woldbe better in the cold, maybe not though
Old 02-11-2007, 12:18 AM
Four Eyes
Four Eyes's Avatar
I dont know if this will help but my 86 was doing something simular, and it was my TPS. We adjusted the voltage to it and the idle smoothed out. Just my two cents.
Four Eyes is offline
Old 02-11-2007, 12:21 AM
90Lxstanger
hmmmmmmmm good thought. my idle is fine and everything. how do you adjust the voltage, or better yet how couldyou test it to make sure its right? a voltmeter or what, and anyone ever hear of wallering out the screw holes on slightly turnt th sensor for better readings or whatere?
Old 02-11-2007, 12:25 AM
Four Eyes
Four Eyes's Avatar
You got it. Dont be scared to drill the holes a little bigger. We had to drill mine. You will need to take a volt meter to the green wire and to a ground. Just turn the TPS slightly until you get desired voltage.
Old 02-11-2007, 12:27 AM
90Lxstanger
really thats interesting, does it help with performance, or is it just a way of running better/ smoother?
silver91gt
silver91gt's Avatar
test the voltage between the green and black wires(, or ground) key on engine off
should be around 0.98volts
Quick Reply: warm/cold doestn matter
