speedo help
speedo help
ok my speedo gauge on my 91 GT never tells me an exact speed it is always jumping around, so to fix it i need to know if the speedo is electronic or does it use a cable
RE: speedo help
its a cable. like 20 from vatozone i think... if you mean it jumps from like 0-30 i think thats normal... mustangs are used to going fast not slow... thats my explination for that happening lol...
RE: speedo help
i had the same problem, people told me it was the speedo head. so i just bought a whole new cluster off ebay with white faced guages. it cleared up the problem. but i was out 100 bucks. you might try taking it apart and cleaning the magnets
RE: speedo help
no like i said in the above post i would b doing like 40 and the speedo would b jumping from 80-140 andeven if i stop at a light it says im doing 40, it varies each time so is there any explanation as to why is it doing that or is the cable just need to b replace
RE: speedo help
The cable will not cause it to stay on 40 at a stop light. That is the speedo head. But, the cable will cause the speedo head to go bad. I have replaced a speedo cable, not bad at all. You can get them at 50resto.com
Mark
Mark
