any one on here with a similar setup
a local shop claims that i will make roughly 320 rwhp but reading some of the threads on here it doesnt seem like it
do any of you have a similar setup and if you do what kind of power did you make
94 gt
Trick Flow Track Heat heads, holley systemax, afm n41 camshaft, 24lb injectors, power pipe, 95mm maf, 75mm throttle body, mac longtubes, dr gas x pipe, mac cat back, fuel pressure regulator 1.6 rr, ac delete
94 gt
RE: any one on here with a similar setup
ORIGINAL: Chitown racer
The Throttle body and MAF are alittle on the big side. I ve seencars make more hp then thatwith just a 70mm throttle body and a 76mm MAF
