update on the shaking issue!!!!
ok so today i finally jacked it up and checked for movement in the tires. on the driver side, i can move it from side to side quite a bit and the brake caliper moves along with the disc and the wheel. the passenger side just moves from side to side without the movement in the brake caliper. what is the problem?
RE: update on the shaking issue!!!!
sounds like wheel bearings... you should actually jack up one side at a time because if you pull too hard, your just turning your steering... you need it to stay stationary to feel for bad bearings and such. however, if the whole thing is moving, brakes and all.. you probably have a bad tie rod end
ORIGINAL: elmustang5.0
if its the bearing you should be able to hear a noise or feel somting on the hwy( like deacceleration , or at certain speed)
atleast thats the way mine was.
ORIGINAL: 5.0stanger
That doesn't sound like a bearing, they are supposed to move together...how much does it move?
yeah the bearings were all messed up and i just replaced them. i still havent test drove it because i have to bleed the brakes but there is no movement in the rotor anymore.
