GOT MY SOUTH SIDE LIFT BARS ON!
#21
RE: GOT MY SOUTH SIDE LIFT BARS ON!
ORIGINAL: luckythirteen13
no, lift bars are a type of lower control arm. lift bars change the geometry of the suspension by lowering the rear mounting hole. normal control arms bolt right up in the stock locations at the body and the axle. lift bars dont. they mount to the body in the same place but they dont mount to the same place on the axle. there is actually a separate bracket that bolts to the stock location and the lift bar mounts to that.
i have since lowered the mounting point to the lower hole which provides more traction but not recommended for the street because it causes the car to strike the tires harder, but for a shorter amount of time. good if running drag radials or slicks
ORIGINAL: 86 5.0L
so lift bars = lower control arms?
#22
ORIGINAL: 86 5.0L
i also had mine set to the lowest setting to help with traction
#23
http://www.jegs.com/webapp/wcs/store...51250_-1_10441
http://store.summitracing.com/partde...5&autoview=sku
Does ant one know which is better, and why?
09-16-2015 07:53 PM
09-01-2015 08:16 PM
