Rev Limit
Rev Limit
*L* I just wanted to know bc i havent really pushed my stang much since i got it bc i needed tires and i just got some the other day. I usually shift at like 5k when im getting on it...should i go higher?
Rev Limit
TAKE YOU CAR OUT AND RUN IT HARD SHIFT AT DIFFERENT RPM POINTS. YOU WILL FEEL THE CAR PULL DOWN OR SOME WOULD SAY FALL ON IT FACE. YOU WANT TO SHIFT JUST BEFORE THAT. PRACTICE MAKES PERFECT. AND WHEN YOU FIND THAT SPOT GO BUY A TACH WITH A SHIFT LIGHT AND SET IT TO THAT RPM AND YOU WILL NAIL IT EVERY TIME!</P>
Rev Limit
6250 is all you need on the street if you get beat @ that rpm....then do some work....after 6250 on mostyou'll start to hurt the engine when you up it to 7k and you miss a shift and the engine is feel willing at 7 k your engine is going to thank you in the most horrible way
Rev Limit
2500 is all you need on the street. The point is that my rotating assembly is balanced and my valvetrain can handle higher RPMs, so I'd like to be able to take advantage of it just for ships and giggles. <img border="0" src=smileys/smiley1.gif border="0">
treesloth
09-28-2015 07:03 AM
Offendant
09-23-2015 07:21 PM
