Timing Question
Old 02-16-2007, 12:38 PM
det45
det45's Avatar
Default Timing Question
Can a EFI 5.0 run 180 degrees out? I was checking the timing on my 90 LX and could not see the timing mark yet, if I shine the timing light under the car 180 degrees oppisite of the balancer I can see the timing mark. Help....Note: my car runs great but no timing mark? (I did pull the little plug on the harness next to the dist before checking the timing and connected the timing light pickup to the #1 plug wire on passinger side)
det45 is offline
Old 02-16-2007, 12:47 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
Default RE: Timing Question
if u cant see the timing marks get under you car take some WD-40 and clean off the rust and then take white out and mark the timing mark u wanna run i did this its easy to see the white out mark... dont lose the spout clip either.. there like 20 bucks or somthan i think... i dont rememeber... but yea i was a dumbass and lost mine so i had to get a new one
CrazyCobraSpeed is offline
Old 02-16-2007, 04:35 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
haven't seen a car run 180 out..sure your using no1 plug? chaulk works great on the HB
2 kwik is offline
Old 02-16-2007, 04:47 PM
vristang
vristang's Avatar
It may try to run, but you would know something serious was wrong.
Another problem could be that the outer ring of the damper may have rotated. This will happen when the damper gets old, and the rubber ring starts to deteriorate.
jason
vristang is offline
Old 02-16-2007, 11:28 PM
hellas85stang
hellas85stang's Avatar
no
hellas85stang is offline
CarrieS
09-01-2015 01:00 PM
GimpyHSHS
08-29-2015 06:30 PM
Calizic
08-28-2015 01:46 PM
stormesixx
08-25-2015 09:11 AM
ding56
08-14-2015 02:40 AM
Quick Reply: Timing Question
