Vortech oil leak??
Old 02-17-2007, 03:53 AM
tckylem
tckylem's Avatar
Default Vortech oil leak??
I have discovered a slow oil leak. How common is it for a Vortech to have an oil leak? Either in the pan tap or line?
thanks
tckylem is offline
Old 02-17-2007, 11:24 AM
luckythirteen13
luckythirteen13's Avatar
Default RE: Vortech oil leak??
its not common. sounds like you intalled something wrong
luckythirteen13 is offline
Old 02-17-2007, 12:57 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
where is the leak? if it's in the line connection then try some teflon tape on the thread
2 kwik is offline
Old 02-17-2007, 01:25 PM
Glasersil
Glasersil's Avatar
I would not use teflon tape. As it may get into the line and clog the supercharger. I used a very light silicone on the threads and the end where I knew it would stop and not get into the line. They say not to put any at all but I had a small leak.
Glasersil is offline
Old 02-17-2007, 01:26 PM
tckylem
tckylem's Avatar
I am not even sure if the leak is comming from the SC. It just happoend last night I am going to lift the car in a few minutes. Hopefully it is just a loose filter for plug.
I was just wondering if a SC leak is common.The procharger on my Z06 is self contained.
Thanks
tckylem is offline
Old 02-17-2007, 01:29 PM
Glasersil
Glasersil's Avatar
Procharged Z06....yikes!
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: Vortech oil leak??
