just finished exhaust...
so i just finished installing my bbk shortie headers and bbk xpipe, was not as bad as i thaught. didnt have to jack the engine up or anything, fell right into place... everything that i disconnected i put back together, although my interior is out except the dash...
so here is my issue, the car turns on and can crank but the fuel pump wont turn on. when i turn the key i hear the fuel pump relay click but i dont hear the whine of the pump turning on. i tested the wires in the back and its getting volts...
any ideas or suggestions where to look at?
RE: just finished exhaust...
ORIGINAL: AdderMk2
have someone turn the key while you smack the tank with a rubber mallet... if the pump is stuck, this trick will un-stick it... however its a sign that you need a new pump
so i just jacked up my rear and my friend turned the key and the pump came on... have really low fuel, could that cause it? im filling up a tank and gonna put it in and see what happens...
uberstang1
09-20-2015 06:42 PM
09-16-2015 07:53 PM
