PROBLEMS PICKIN A CAM
RE: PROBLEMS PICKIN A CAM
ORIGINAL: OnyxCobra
not a bigger cam, but too big of a cam. Bigger does not always mean better.
ORIGINAL: jtmustang
HOW CAN A BIGGER CAM HURT ME?
ORIGINAL: 2 kwik
we have some people on when helping other pic a cam that have NO DAMN CLUE ON WHAT THEY ARE SAYING... I have seen the stock cam in a N/A go 12's easy
ORIGINAL: OnyxCobra
What are some of those setups? I have heard the stock cam isnt bad.
ORIGINAL: 2 kwik
If you had a B cam, or still have it. and want a quick upgrade... toss some 1.7 roller rockers on it and call it a day
ORIGINAL: OnyxCobra
Well my point being if the car with a stock cam has low gears, slicks, drag suspesnion and a shot of nitrous i hardly consdier that being "12s easy" with a stock cam
Man here we go with the cams again. How come no one says Isky cams are good? My teachers have told me that isky makes the highest quality cams you can buy. Doesn't comp make trickflows cams? if so i wouldn't get one. Too big of a cam is only going to hurt you if your heads and intake system dont match. For example the stock system is good for like 5000 RPM. If you get a cam that makes its peak power at 6500 RPM then your not going to be very happy with your set up. Lots of duration isn't really going to hurt you. Its lots of lift that will, tons of lift is going to give you less port velocity and thus less low RPM torque. If you want a cam thats going to get you a good ET and get you lots of power and you dont care about street manners then get big heads and a big cam and a big intake. If your driving it everyday and you want that torque to push you in the seat from stop light to stop light then your going to need a cam that makes power up to about 5500 rpm. If I were you I would look at the rpm ranges of the induction system you wanna buy and the cam you want. LSA also matter as well as overlap, to be honest with you, you could just ask the tech guys at isky or trickflow or ford racing.
sorry... the website i gave you the guy really knows his stuff and will make a custom grind cam for a reasonable price that'll make more power than you thought would be immaginable. he'll talk to you on the phone for hours trying to work with you on your setup
