explorer setup
RE: explorer setup
older explorers have the gt40 heads, and I believe 97 and newer have the gt40P heads. You will get fairly decent gains from them, if you are on a budget I would go with them or if you got some cash just get some aluminum heads like AFRs.
RE: explorer setup
Don't forget that the post-'97 1/2 Exploders had GT40P heads, which were a bit hotter stock but less potential in the long run. The main consideration with these heads is that they require a special set of headers. Go with the standard GT40's
