BBK 65 MM TB TANNY CABLE PROBLEM??
Old 02-19-2007, 12:22 AM
mysticstang
mysticstang's Avatar
Default BBK 65 MM TB TANNY CABLE PROBLEM??
i havea 92 gt ho aodithas a bbk65mm tb my problem is that the tranny adjustment cable fell off of the it i have it ziptied right now, it happened before i stored it for the winter so ineeded a quick fix to get it to the storage garage,but its getting close to pulling it out again and i need to know how to put in back where it belongs and how to adjust it if need be any help or tech articles would be great i couldnt find any thanks Ben.
mysticstang is offline
Old 02-19-2007, 01:03 AM
Js04sILVerBullet
Js04sILVerBullet's Avatar
Default RE: BBK 65 MM TB TANNY CABLE PROBLEM??
There is a little round rubber bushing that holds it in place.I would go to your local parts store and get one or take to a tranny shop and have them put a new one on it (but don't drive it without out the tv link hookedup, make sure it is hooked up before u drive itor u might screw ur tranny up!) I had the same thing happen to me and a local tranny shop only charged me$10 to put a new bushing on it.Andthe tv cable shouldn't need to b adjusted as long as u didn't remove thatlittle white clip that adjust the slots on it.
Js04sILVerBullet is offline
Old 02-19-2007, 07:54 AM
veto227
veto227's Avatar
+1, DON'T DRIVE ITuntil you get the tranny linkage hooked back up. As long as you weren't having any issues prior to it falling off you should be ok with its current setting. Very easy to replace it. Any local tranny shop should have the bushing to replace inyour throttle body. Ask for a brass bushing.....
veto227 is offline
Jb145700
08-21-2022 06:37 AM
Luke9222
10-22-2015 11:55 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
DoctorScary
09-09-2015 07:53 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: BBK 65 MM TB TANNY CABLE PROBLEM??
