Got my 3.73's in...
Old 02-21-2007, 11:40 AM
  #21
ToplessGT
ToplessGT's Avatar
Default RE: Got my 3.73's in...
give it a little break in time. I was told i didnt have to, but at least get some heat through them and make sure everything works right before going out and mashing it. Some people say 500 miles, I think thats ridiculous, but whatever. As long as they are put on right and shimmed correctly, you wont have problem, (well i didnt anyway). yeah, gears rule!
ToplessGT is offline
Old 02-22-2007, 12:56 AM
  #22
easter9053
easter9053's Avatar
ORIGINAL: 95walter
a speedo gears will fix you speedo problem and you should have to run different gas unless you mess with your timing. and as far a break in when i got mine put in the guy said they are either rightor wrong and he races mustangsand hehas done hisfair shareof rearend work
What's a speedo gear and are you saying that you do have to use 93 octane fuel or 87? I haven't messed with my timing yet? Are you saying that if I bump my timing up that I should or shouldn't have to use higher octane fuel. Please clear me up with these question. Thanks in advance.
easter9053 is offline
Old 02-22-2007, 01:08 AM
  #23
LTnone
LTnone's Avatar
The "break in" period isn't to wear the gears together or anything like that, it's merely to take it easy for a while to make sure stuff was done right, so in case it wasn't you're not raggin on it and screwing it up more.
Gears don't affect gas, use 87. A speedo gear recalibrates your speedometer for the different gears (makes it accurate). When you bump timing you want to increase octane
LTnone is offline
Old 02-22-2007, 01:37 AM
  #24
Dubs
Dubs's Avatar
How do you like your 3.73's?
ORIGINAL: LTnone
Dubs is offline
uberstang1
12-07-2017 07:10 AM
JoePSL
08-24-2016 02:50 PM
Darien
09-16-2015 09:30 AM
Kenta08
09-02-2015 10:33 AM
gus_vb
08-29-2015 11:35 PM
Quick Reply: Got my 3.73's in...
