A/C Delete
Old 02-20-2007, 07:44 PM
91stang
91stang's Avatar
Default RE: A/C Delete
so if you don't have a SN95 then you can't just disconnect everything?
91stang is offline
Old 02-20-2007, 07:53 PM
AdderMk2
Banned
AdderMk2's Avatar
you can simply eliminate the smog on a fox, by running a shorter belt. however, the relocation bracket for the PS is a really good idea instead of trying to leave it down low where it is
AdderMk2 is offline
Old 02-20-2007, 07:57 PM
91stang
91stang's Avatar
if i were to take off the AC then what should i plug everything up with? i have the SC delete belt from autozone but haven't done anything yet
91stang is offline
Old 02-21-2007, 04:13 AM
95 droptop
95 droptop's Avatar
i was told the bolt size was a 9/16. i have the write up here telling me that. so which is it. need to know if i need to stop by lowes before i go to work in the morning.
95 droptop is offline
Old 02-21-2007, 10:01 AM
MrMiracle
MrMiracle's Avatar
Tool-wise I used 9/16th, an adjustable wrench for the bigger connections, a hex-key set, and I had to buy a set of those little plastic hose de-couplers. Y'know the kind that are for disconnnecting fuel and A/C lines. You'll have to pull the radiator if you want to get to the A/C heat exchanger. Once the compressor is off, you shouldn't need the mounting bracket underneath anymore. I could be wrong, but I don't think that it holds the power-steering pump or anything like that.
If you really, really hate your A/C tubes, you can always just hacksaw them out.
MrMiracle is offline
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
69Volunteer
09-30-2015 10:39 AM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
Quick Reply: A/C Delete
