just hit it with a hammer...
#21
RE: just hit it with a hammer...
ORIGINAL: LCBlackDep183
Heres a solution to get both the tie rod, and the stuck rim off... Get a plasma torche and cut the differential about 1/4th of the way to the "pumpkin" in the middle... Then cut all other support devices...
#22
Try to thread the nut on a little bit and hit the nut. Be careful not to thread it on to where threads can be seen, you will mushroom them. I used to do this all the time with great results
#23
ORIGINAL: nmerrill
#24
haha how come anytime i post something about this someone says something about the rearend, anyways its a lock holding it on and no key... and i didnt try using a really heavy hammer but i hit it pretty hard
#26
mine was stuck like that[:'(][:'(][:'(][:'(][:'(][:'(][:'(][:'(][:'(], I used a hamer so big, the knuckles were starting to get damaged.
heat up the hub and then spray it with pb blaster while hot, then hammer out in 4 mins, that sucks azz[&o]
