Question on junkyard heads...
Old 02-21-2007, 01:50 PM
LCBlackDep183
LCBlackDep183's Avatar
Default Question on junkyard heads...
So once I finnally find a pair of gt-40s in a junk yard around here what process should i take to get the heads cleaned and performing best... I know a guy who can do a 5-angle valve job... What parts am i going to have to buy or am i going to be able to re-use. Im planning on getting 1.7 RRs anyways but for the valve job do i need to get new seats? Also to get the head cleaned should I take it to a shop and have it cooked or just clean it myself. And as far as checking for cracks is magnafuxing a expensive thing or even necissary?
LCBlackDep183 is offline
Old 02-21-2007, 01:54 PM
mattdel
mattdel's Avatar
Default RE: Question on junkyard heads...
do some shopping around for machine shops, ask for quotes. cleaning, magnaflux, everything you need for 2 heads should be around $800, toss in another 500 for the valve job
mattdel is offline
Old 02-22-2007, 01:28 AM
LCBlackDep183
Why the hell would i pay that and not just get afr 165s for 1200 bucks?
Old 02-22-2007, 01:31 AM
ZachW04Stang
ZachW04Stang's Avatar
I would just get the heads milled down, get springs that match your cam and replace the valve seals and through them on. Getting them hot tanked shouldn't cost more then $100 if you want them really clean.
ZachW04Stang is offline
Old 02-22-2007, 01:44 AM
LCBlackDep183
How much do explorer gt-40s have to be milled to reach 9.5:1 or 10:1 compression? Know where i can get some new valve seats?
Old 02-22-2007, 02:26 AM
LCBlackDep183
tt
Old 02-22-2007, 06:20 AM
89 NoTcH
89 NoTcH's Avatar
TTT i am wondering the same thing.
89 NoTcH is offline
Old 02-22-2007, 10:54 PM
LCBlackDep183
Man you all are being really helpful on this one.
Old 02-22-2007, 10:56 PM
stangman94
stangman94's Avatar
i payed 100 buks to get mine checked out to see want i needed to get done.
stangman94 is offline
Old 02-22-2007, 11:03 PM
ZachW04Stang
Most people get the heads milled .030-.040 from what I've seen. Getting new valve seats is going to be exspensive. If your going to do a complete rebuild of new heads your might as well just get a set of aluminum heads for a couple hundred more.
Quick Reply: Question on junkyard heads...
