Edlebrock performer intake?
RE: Edlebrock performer intake?
Eddies are the best intakes out there... Theres been many shootouts on them and across the board the eddie is the best flowing consitant intake.... TFS and Holley perfrom higher at higher at different rpms, but lower they suck alot more than the eddie....
And +1 for the Blue Oval Typhoon intake, thats what im buying 279 vs 559? No brainer... Just requires a day with a dremel which i dont mind at all
yeah i would get it i love it gives goodmid and excellent high power hardly any low but when your racing you aint in the low range i mean i have one on my car now
i know i said no but you cant compare it cause they are all different designs depends on if you want low mid or high this is good mid and high mix box r is good for 4500-to when your car stops revin but the rpm makes power pretty good in 3000 area also depends alot on the cam if you have a low end cam you need a low end intake same as the high end
