tranny problem
Old 02-22-2007, 02:51 PM
  #21
dimebag
dimebag's Avatar
Default RE: tranny problem
you can still adj the stocker tho...
dimebag is offline
Old 02-22-2007, 02:54 PM
  #22
94gtcoupe
94gtcoupe's Avatar
ORIGINAL: dimebag
go ahead and throw i clutch in it too... already that far, might as well spend a lil more, and eliminate one more thing...
WOW dimebag is getting smarter
94gtcoupe is offline
Old 02-22-2007, 02:59 PM
  #23
dimebag
dimebag's Avatar
ORIGINAL: 94gtcoupe
ORIGINAL: dimebag
hah, yea i shoulda done my clutch when i did my trans... now its slippin... dammit[:@]lol
dimebag is offline
Old 02-22-2007, 03:00 PM
  #24
15austin
15austin's Avatar
You can adj the stocker, but at the end I adjusted mine everyday it just kept slipping out. Bought a BBK one and problem solved for 7 years now.
15austin is offline
Old 02-22-2007, 03:02 PM
  #25
94gtcoupe
94gtcoupe's Avatar
i retract my previous statement... he can't use the quote feature
ORIGINAL: dimebag
ORIGINAL: 94gtcoupe
ORIGINAL: dimebag
  #26
dimebag
dimebag's Avatar
yea i no u can, im just sayin, why would he buy an and one 1st... id adj the stock one, and then no if thats the problem atleast...
i have to adjust mine once every two weeks or so... i just reset it, then go w. 2 clicks
dimebag is offline
Old 02-22-2007, 03:04 PM
  #27
15austin
15austin's Avatar
Fair enough. Adjust the stock one it may fix it.
15austin is offline
Old 02-22-2007, 03:06 PM
  #28
dimebag
dimebag's Avatar
ORIGINAL: 94gtcoupe
ORIGINAL: dimebag
ORIGINAL: 94gtcoupe
ORIGINAL: dimebag
hahahaha..... better? lol
dimebag is offline
Old 02-22-2007, 03:15 PM
  #29
94gtcoupe
94gtcoupe's Avatar
yup
Old 02-22-2007, 08:08 PM
  #30
89 NoTcH
89 NoTcH's Avatar
ORIGINAL: dimebag
does it do it in a select few gears? or every single one?
when your moving, and shifting hard, a. is it possible? and b. do you get any grind at all? if so, all or which gears?
how long ago was the clutch replaced? if you know.
whenever it does happen it is all gears. well i usually dont even try fith. and when moving it has never happened. and the only time it grinds is when going into reverse sometimes. and i have know idea about the clutch, i have only owned it for about 6 months. once again thanks for all the help from everyone. i am still going to try adjusting the clutch as soon as i get time.
89 NoTcH is offline
Quick Reply: tranny problem
