3.73's to 3.55's
Old 02-22-2007, 03:18 PM
reduceallpain
reduceallpain's Avatar
Default 3.73's to 3.55's
Now i have 3:73's in my car and hate how the gears are shorter and how i lost a lot of top end... If i was to switch to 3:55's would i get some top end back? If so how much?? Would i just be better goin back to the stock 3.08's? Also... If i kept the 3:73's in and got heads and a supercharger and i'd get like 80 hp from that.. Would i get longer gears or more of a top end?
reduceallpain is offline
Old 02-22-2007, 03:21 PM
w8less
w8less's Avatar
Default RE: 3.73's to 3.55's
where are u driving so fast that u need that much topend. when i had the 3.73's in my car i could stil do like 120 do really need to go anyfaster?
w8less is offline
94gtcoupe
94gtcoupe's Avatar
well i can do the math and show u your final drive for both gears if you want, and i can show you what the MPH difference would be at a given RPM between the two gear sets
94gtcoupe is offline
Old 02-22-2007, 03:32 PM
94gtcoupe
94gtcoupe's Avatar
in fifth the gear ratio is .68 so with 3.73's the final drive is 2.54 and with 3.55 the final drive is 2.42 so not much ofa difference, now lets look at the MPH difference
at 2000RPM in fifth with the 3.73 you'll be at 60 MPH and with 3.55 you'll be at 63 MPH
at 6000RPM in fifth with the 3.73 you'll be at 180 MPHand with 3.55 you'll be at 190 MPH
going from 3.73's to 3.55's is realy a waist of time because u won't get much top end back
Old 02-22-2007, 03:35 PM
dimebag
dimebag's Avatar
3.73 to 3.55, wtf? thats not worth it... id get used to what you have, or throw your stockers back in...
dimebag is offline
Old 02-22-2007, 03:38 PM
94gtcoupe
94gtcoupe's Avatar
it's like 3.73's to 4.10's not a big enough difference to matter or to waist the money on
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
honestly it would be a waste of money going down to 3.55 ... ull gain mayb 12 more mph... if that... if u wanted more top speed get a t-56... if will give u that extra gear thats rite below 1.00... im think its .87 so ull pull like anotehr 30-45 mph probably.. its kinda also depends on you tire diamiter
CrazyCobraSpeed is offline
Old 02-22-2007, 03:40 PM
Ninety5five0
Ninety5five0's Avatar
I can hit 125 with 4.10s. So i assume you can go quite a bit faster with 3.73s. Unless your runnin like 8's in the quarter theres really no need unless youl ike to cruise goin like 150.
Ninety5five0 is offline
Old 02-22-2007, 04:03 PM
94gtcoupe
94gtcoupe's Avatar
t-56 6th gear is .62 which is longer than the stock t-5's .68 and the viper spec. t-56 is .50 in 6th
ORIGINAL: CrazyCobraSpeed
Old 02-22-2007, 04:19 PM
OnyxCobra
OnyxCobra's Avatar
This is definitely not something you see every day and one reason i went on the conservative side. If you are going to be adding heads and a supercharger you'll gain more than 80hp, and IMO 3.73s will be too much for that combo, unless you build the rear end and run slicks. 3.55s FTW
OnyxCobra is offline
Quick Reply: 3.73's to 3.55's
